I need to convert a linear displacement of 700mm to a rotation with an accuracy of at least 0.1mm/Revolution. The linear movement has a maximum velocity of 40 mm/s. The rotation side is linked to a encoder wich has praticaly no mechanical resistance. Who has any experience with this subject. Wich mechanical equipment is best suited? A belt, bearing or spindle construction? Are there of the shelve solutions available?
