I have a main line of methanol that splits in two identical lines. The flow on those two lines is measured by two identical Coriolis mass flow meters. The methanol passes then through two separate pre-heaters before entering two vaporizer exchangers.
My problem is the following: when the temperature drops below -10ºC (14ºF), the HI-flow alarm on one of the meters is triggered once or twice per week, shutting down the entire plant. The problem occurs ALWAYS on the SAME LINE and it lasts for 30 seconds max.
We switched the two meters but the problem remained the same. The two meters are also fed by the same power line from a UPS. Finally, a technician from the manufacturer confirmed that both devices are in perfect condition.
Can anyone help me. I considered cavitaion in the pipes, but it's doubtful.
Alejandro Posada
Alejandro Posada
