Hi guys,
I have a CQM1H (CPU11/12), DA041, SYSWIN 3.4. The main speed of the machine is controlled with a inverter (0-10V, DA041). The DA041 is connected to inverter to chose the speed.
An operator will set the speed of the machine through a SCADA application. The operator will work with a scale from 0.xx (Hz) to 59.xx (Hz).
00.00 --> 00.xx Hz
03.23 --> yy.zz Hz
05.00 --> 30.00 Hz
10.00 --> 60.00 Hz
How may I set up this scale?
Thank you in advance for your help.
Max
00.00 --> 00.xx Hz
03.23 --> yy.zz Hz
05.00 --> 30.00 Hz
10.00 --> 60.00 Hz
Max
