I am hoping that someone can provide me with some information regarding crank cooling. My plant consists of 4 GE 7FA.04 GT's, and 2 LCI's. There are some senior employees who believe that crank cooling is not a good practice, but if it is necessary you should crank for 15 minutes, and then coast down for 15 minutes before cranking again. You would do this until wheelspace temps are below 150F.
In the research I've done it seems most facilities have their own procedures for accomplishing cooling via cranking, and there is not a set standard. Has anyone ever come across a GE technical standard regarding crank cooling? Even if you've never seen GE documentation, I'd still appreciate your input.
If you guys need anymore info about our plants set-up I'd be happy to elaborate.
