Cutting CanBUS
E
elohim
The idea is that a PLC operates usually autonomous (without conections). If I want to change parameters, I "switch" on the conection (with a switch), perform the changes and switch the conection off. I am looking for a physical broken bus, not a software solution. (If this is not the right place to ask such a question: sorry!)
H
Heinz-Juergen Oertel
<P>>Is it possible to "switch" on and off a CanBUS?</P>
<P>You can not switch on/off the bus, whatever you mean with this.
But you can connect/disconnect devices, without interferring others working on the bus, also with a switch.
Only remember basic network rules for a line of twisted pair cables.</P>
<PRE>
XXX
+-|-------- node 1
CAN trunk | +--------
--+ \+--+ | =20
node x \ | | CAN-line
--+ \+--+ |=20
+-|------- node m
XXX
termination
</PRE>
<P>in this case you can disconnect node x without disturbing the CAN network</P>
<P>with best regards / mit freundlichen Gr=FC=DFen
<BR>Heinz-J=FCrgen Oertel
<BR>| Heinz-J=FCrgen Oertel
<BR>| port GmbH phone +49 345 77755-0
<BR>| Regensburger Str. 7c fax +49 345 77755-20
<BR>| D-06132 Halle/Saale mailto:[email protected]
<BR>| Germany http://www.port.de</P>
