CVIM2 Interface
A. Wiest
I have 3 CVIM2 units mounted internal to a power cabinet, and it is a hassle to manually switch between each unit to monitor what's going on with each system. I have also noticed that the system will lock-up if I don't get both the VGA and mouse plugged in almost simultaneously, and the only way that I know of to correct this problem is to power down and start over again... Also a hassle. My question is if anyone knows of a unit designed specifically for the Allen-Bradley CVIM2 system that will provide for switching between units without the need for a keyboard or external power supply, and that doesn't take up alot of room. I've been looking but haven't seen anything I like... Any info is helpful, and thanks in advance...
Aaron
