I am trying to communicate via http web-services with the DANFOSS AK-SC255 controller. Most of the communication is working, and I have no reason to believe there is an error with the communications.
However, there is a command read_parm_info that I require. One of the parameters in the message is the Device_ID which I have no clue how to get this.
The manual says it is the ID of the Model and Version No. separated by an underscore. The version no can be found in a EDF with the model name.
Firstly I cannot find a EDF file with this model name (the model is 080Z2350). I believe this is a device configuration issue, and that for some reason the device does not have an edf file.
I would really appreciate any advice.
