Hi, Thank for the space to have this conversation
I'm a mechanical engineer who works in an NGO with small water and sanitation projects. We are developing a solution to water chlorination that uses a dosing pump to inject a chloride solution directly in a water pipe line. The villages we work with are quite far, so we need a system that measures the chloride, ph and water flow, stores and sends the information via GSM, for example. Due to the caractheristics of projects, we can´t afford expensive solutions. Would you recomend a data logger that could get the info we need, with a fair price?
Thank you very much
Thank you very much
