DATA LOGGING TO EXCEL IN RSVIEW32
  • Thread starter FACTORY AUTOMATION SYSTEMS LTD
  • Start date
F
Dear Automation list,
Does any one know of a simple method of logging data to MS Excel in Rsview 32 instead of the default that is dBase 1V format?
Thanks in advance,
Gabriel
Juan De los Santos
Do you know Excel can open the Dbase files?
Just select on the file type selection box "Dbase Files".
Good luck
F
Dear Sir,
Please do send me the VB code to do to write log data into excel from RSVIEW32.
I will appreciate you kindness.
Many thanks,
Gabrieli
Could you send me a copy of the VB code to write data to excel. I want to use it to trend data from a Modbus RTU slave.
Venky
Stephen Sharp
This works only if the file is small with limited tags beinged trended. More than a dozen over a day and excel cannot open the full file due to the limts on rows. ~65000
