R
I'm using MCM 3150 to receive data and send data to/from a device. The PLC i'm using is SLC500. But recently, i facing a problem:
When i pulled data from a device through Master Port (port 1 of the card) and send out to another deviced through Slave Port (port 2 of the card), it seems that there are some different after send out through slave port. For Example, i received a value 45.56317, 1.325531, 47.29668, 0.5380074 from a master port, then send out through the slave port, the results will be 45.5000, 1.3223, 47.4170, 0.5352. The values that i pull will not keep changing, and it is ENRON Floating point. But i send out through Slave Port will be normal floating point. I had tried to slove this problem, but finally failed.
Conclusion, the values that i send out are different with what i have receive.
Therefore, i hope that i can get help in this forum.
Thank you.
Thank you.
