i have confuse in DCS wet/dry digital output module. We have mitsubishi netmation DCS and there is two module wet and dry digital output modules.
so far i know that wet contact output module will give direct signal from the module itself, for example direct power to operate solenoid.
While the dry output module will close external circuit to give power to the solenoid!
please correct me if I am wrong!
so i can energize the solenoid if i used any module whatever wet or dry! am i right?
If it so, what is the application that requires wet contact digital module and what is the application requiring dry? please give me examples
also to eliminate the doubt can u please tell me if i measured the voltage by voltmeter of the dry and wet contact what shall i get in OFF and ON position?
thanks
thanks
