Decoding Siemens VSD param number from Fanuc RX7i Profibus message
Chris
The control system uses several Siemens Simoreg DC drives which are controled over Profibus using a GE Fanuc RX7i VME bus PLC. They have been assigned nodes 1,2,3,4 & 5. There are other data acq. systems and GE PLCs on the network all using reflected memory.
I cannot figure out how to decode the words in the %R registers to the VSD parameter number, index, value etc. The message format is PPO5. I am trying to use a spare analog input on the VSD. There is another analog input being used, but I cannot figure out how to decode the R/W message to determine the param/VSS info.
I am way behind since I've never used GE plc's or Profibus. Any and all comments welcomed.
