Our two 1994 vintage Westinghouse gas turbines have a premix setup for denox steam and natural gas. Both are combined into one pipe about 30 feet from the combustors. We have been having erratic emissions in one of the machines ever since our gas heater was sent out for repairs. This heater was a retrofit four years ago to improve performance by preheating the natural gas up to 275F from 50F. Currently our NG temperature is 32F which I suspect is causing a loss of too much superheat to the denox steam once its blended. Can anyone tell me what the parameters are of the mixture after it passes through the Y fitting?
Pipe 1 (NG with a 4" ID) = 24.1kpph flow/326.7psig/35.4F
Pipe 2 (steam with a 6" ID) = 37.4kpph flow/393 psig/581F
Pipe 3 (mixture of both above with a 6" ID)
The CT's are designed to run with cold gas but I suspect it shouldn't be this cold.
