A Thread Starter aidanbrennan Aug 21, 2001 #1 i need to design a4-bit gray code to binary converter that counts up to 1111.what then would be the output counting sequence
M MiG Aug 21, 2001 #2 Answer: Gray code principle: only 1 bit changes at a time Here is the sequence: 0000 0001 0011 0010 0110 0111 0101 0100 1100 1101 1111 1110 1010 1011 1001 1000 If you place these numbers in a column, you will see the logic behind the Gray Code.
