E
I've got an ABB AC800M PLC (PM851) that I've installed at a customer's site. I also have two ABB PP845 10" touch panels and two signal towers with three colors (yellow/blue/green) connected to DO's through a couple of relays.
Is there a simple way of activating the yellow lamp for all unacked alarms with severity >600, the blue lamp for acked but active alarms and the green light when there are no active alarms?
I have searched the documentation for both the PLC and the panels but to no avail. I seem to remember seeing something about alarm groups based on severity in the panel software but can't find it today. I think the panel could detect the severity and status and then set an access variable which would could then be connected to the DO input. However I also think there should be an easier way of detecting an alarm in my code, without having to go through the panel.
(The long, tedious way would be to connect all GTHH/LTLL outputs to a Uni-block)
