H
I am looking for information as how to detect the leak from milk cartons/plastic bottles. The
cartons are 1/4, 1/2 and 1 litres. The productions rate is about 1-2 cartons per second. The leak in the cartons happen either from the bottom of the carton(first sealing process when carton is empty) or the top(second sealing when carton is full). In the case of plastic bottles leakage occurs through an occasional pin hole. The company currently uses an operator to squeeze the cartons to check for leak, which is very
subjective and may in itself cause leaks further on.
Looking forward to replies.
Mr Hassan Kaghazchi [email protected]
Mechanical & Aeronautical Eng. Dept., University of Limerick, Ireland
Tel: +353 61 202107 Fax: +353 61 202944 http://www.ul.ie/~arc
