Dears,
We plan to install a coriolis flow meter at our plant, which will be powered by a separate 24VDC power supply. The readings will be transmitted to the controller through Exi birrier MTL 4544A.
Can you tell me if it is possible to use the 4544B barrier instead of the 4544A?
