difference between ppm and vpm
K
kaustubh
what is difference between volume per millions
and parts per millions in case of gas
is there is any conversion factor between them
I
Ian Verhappen
In a word Density. Assuming you mean ppm is ppm(w) by weight. This is why it is ALWAYS a good idea to state what basis you are using for your ppm measurement. vpm = ppm(v).
Ian
Ian Verhappen
Syncrude Canada Ltd.
PO Bag 4009, MD 0032
Fort McMurray, Alberta T9H 3L1
P 780 790-4079, Cell 799-6017
F 780 790-5190
[email protected]
T
Thomas Davis
At Different pressures gases have different densities so the number of mulecules can vary per volume. The conversion would be a simple ratio if you know the number of particles per a given volume at a given pressure and the pressure you are using.
