Hello all,
I have a project using NuFlo Scanner 2000 - Cameron for oil export metering.
The system architecture is using SCADA server – Vijeo Citect that read process parameter from Modbus Register through Modbus gateway EGX100SD.
The problem we face that the parameter reading comparing ModWorx and SCADA is showing different value. (MorWorx is proprietary application to read/calibrate the smart transmitter NuFLo Scanner 200)
I have tested to compare with Modscan32 with Mordworx both using the same serial port (without any gateway) but unfortunately, both still show different indication.
Does anyone have idea to solve the problem?
Cheers,
Chrisman
Cheers,
Chrisman
