We have a pressure transmitter connected to a analog input card through a 3 way DC/DC isolator. HMI reading and local transmitter reading differs by 0.2mA only when plant running. During shutdown if you loop check it has no current drop. i replaced isolator and find the same result. I tried to by pass 3 way DC/DC isolator then I found no current drop. But other analog input loops having isolator has no issues even it has isolator. I don't know why only this loop has issues with isolator.Can anyone advice why current drops only here?
Note: transmitter, PLC analog input card, and isolator receive common 24 VDC POWER SUPPLY. 24 VDC power supply negative grounded.
