P
Hello.
I am working on developing an application for a district cooling company. The company supplies chilled water to multiple high rise buildings and tenant side billing is done through BTU meters.
Now we intend to install valves for each tenant that can be opened/closed from a central location. This way, connection/disconnection of chilled water can be done remotely without anyone going in the field.
Main requirements of such a valve are
1. Should be battery operated with long battery life.
2. Should be wireless.
3. Good option: Should be able to take in M-Bus input from the BTU meter and communicate the meter reading on the same wireless channel through which the valve is being controlled.
I would like to know if members in these forums have ever come across a valve that can do all this?
Thanks for your help
Omer
Omer
