DLMS Cosem to Modbus Protocol Converter
Sami BADER
We are looking for a DLMS Cosem to Modbus Converter.
The purpose is to establish a communication between an Electrical Energy Meter (DLMS Cosem) and a Distributed Control System (Modbus TCP or RTU) in order to have a remote reading of measured electrical energies.
Can you please tell us if SYNC 1000 manufactured by Kalki Communications can be this DLMS Cosem to Modbus Converter?
If not, do you have any suggestion?
A quick answer will be appreciated.
Thanks in advance for your support.
With best regards,
Sami BADER
ALSTOM POWER SYSTEMS S.A.
Thermal Systems Massy
12, Rue Jean BART
91300 MASSY (FRANCE)
G
Hello Sami BADER,
Kalkitech offers DLMS to MODBUS protocol converters. We suggest SYNC 2000 protocol gateways for such requirements.
Our SYNC 2000 can be used to connect the DLMS meter(where the meter can be connected directly to the RS485 port on our SYNC 2000 protocol converter, or if multiple meters needs to be read, they can be multidropped in daisy chain) to the Modbus master device
We have successfully completed numerous projects integrating DLMS Meters to the master devices(which are on Modbus, IEC61850, DNP3, etc)
Here is the link of case study of the recent project which we completed http://www.kalkitech.com/documents/SYNC 2000 Protocol Gateway V2_Case Study.pdf, where we integrated DLMS meters to IEC61850 SICAMPAS system
Best Regards,
Gautam Bhat
email: [email protected]
www.kalkitech.com
Are there any other solutions offered by Marcom and others? Sami did you find the Sync2000 works ??
Dear Dave,
As mentioned before, SYNC 2000 are very widely used across the industry for DLMS to Modbus TCP/RTU conversion.
If you are looking for a DLMS Client with an OPC server, the Kalkitech Meter Explorer(SYNC 6500) would be the correct solution.
We look forward to supporting you on establishing the communication between Electrical energy meter (DLMS COSEM) and the DCS (Modbus TCP or RTU)
Thanks and best regards
Gautam Bhat
