I'm here on behalf of medical device startup. Our device involves a large, rapidly inflating/deflating bladder of air. We need a motorized valve with a high throughput at low pressure: hundreds of liters per minute at 5 PSI. Something in the range of 40Cv, or the equivalent of a 1.5" unobstructed pipe, should do the trick. Speed is key: the valve must be able to fully actuate in under 50ms. Weight and volume are also considerations, especially weight. One thing that can be sacrificed is manufacturing tolerance: this valve will not be relied on to stay closed for extended periods, nor will it be working with gases other than air, so some leakage is acceptable.
I have looked at a couple dozen online catalogues, and didn't find anything that meets this description. It's a big world, and I have trouble believing that nobody has had such a need before. Are we looking in the wrong places, or searching with the wrong terminology? Is there some simple oversight in our design?
Thanks for any direction,
Aidan Paradis
Aidan Paradis
