Hi all, wondering if anyone has run into a similar situation, I have a bore pump being driven by a DOL contactor with a 24VAC coil. I wish to be able to activate the coil via 2 separate 24VAC inputs that can't combine or back feed each other, one is the output from a standard irrigation controller, the other will be via a DIM mount 240VAC->24VAC transformer driving a manual push button circuit on front of panel. Has anyone done something similar whereby the two inputs are essentially kept separate and unable to both active together? a four gang rotary switch would obviously be able to handle the logical switching but wondering what others had done.
Cheers,
Richard
Cheers,
Richard
