Hi, I'm needing help with this program, I really think there is something wrong.
To recap the program belongs to a hot melt machine which sticks the paper for car filters.
It's suposed to control the movement of the nozlet which comes and goes moved by a servo.
The machine was bought secondhand, heavily modified since it was originally built by a now disappeared italian manufacturer.
The plc and the driver should be independent from the rest of the machine but i'm not sure.
There is no hope in finding any information besides some basic manuals from the electronic components.
The problem is that there are inputs and outputs that I can't find in the program which are fisically wired to make it start.
The inputs I have wired are:
x0, x1, x2 These come from the encoder
x7 Home sensor
The outputs:
y0 pulse command, direction
y1 pulse command, pulse
y3 On signal for the driver
y5 God knows where it goes.
The hardware is:
Mitsubishi PLC FX3g-14m
HCFA sv-x3da010a-d
I'm attaching the plc program in hope that someone wiser than me can undertand if it will ever start or there is something missing.
Thanks in advance.
x7 Home sensor
The outputs:
The hardware is:
HCFA sv-x3da010a-d
Thanks in advance.
