Driver for L1 direct and INTOUCH 7.0
O
O. Moret
Can anyone provide any information (detailed or background) on a SINEC L1 (S5-100U/CPU103) direct point to point connection to a WINDOWS NT platform
and Intouch 7.0 SCADA.
Specifically, I am looking for a driver. I have contacted the manufacturer, only the driver used in the past can not be used any more. Wonderware ( the manufacturer ) does not support the SINEC L1 anymore. I have found on the internet only Multidrop solutions with wrong CPU versions. I am searching for a Point to point connection with a S5-100U, CPU 103
With kindly regards,
Onno Moret
Imtech Projects West
Mescon
Control Systems
The Netherlands
tel :010-4477228
fax :010-4477210
mailto:[email protected]
Bezoek onze Internetsite (klik hieronder)
http://www.imtech.nl/ControlSystems/index.htm
Mark L. Hensley
Hello Onno
Is the PLC to far from the NT box to use a programming port driver(AS511)? If not there are a number of AS511 drivers out there that support the 103.
Mark Hensley
President
KEPware Inc.
81 Bridge St.
Yarmouth Maine 04096
PH:207-846-5881
FAX:207-846-5947
WWW: http://www.OPCSource.com
Looking for OPC servers, look here.
Hello Mark,
No . The distance between Pc and PLC is 2 meter.
Met vriendelijke groeten,
Onno Moret
Mescon
Control Systems
tel :010-4477228
fax :010-4477210
