Hello Folks,
I need some information/guidance on what the standard flow testing procedure is of gas turbine's fuel nozzle. In our facility a very peculiar method of testing is used which I can neither decipher nor find any supporting reference. I am attaching the picture of test bench used at our facility, we eventually increase air pressure at out test bench and measure delta across flow line in mmwc. If the values of delta measured at different inlet pressure fall within range (God Knows where that range has come from), we say the nozzle is OK.
I will be really grateful if anyone can explain this / share supporting document.
