I have a 750w electrical hoist from Ribimex (The one in their website is the 1020w version) that I'd like to automate without using the rocker switch. The switch contains a CBB60 dual-capacitor required to start/run the motor. The hoist is required for another function (to open a roof horizontally) and I installed two limit switches to the stop the motor once the limit is reached.
What would be the best way to automate such setup? I actually already did that about 7 years ago and it was working well for the most part but it was too complicated with modifications to the rocker switch along with utilizing external relays and sensors. Can a VFD be used to run this directly without the capacitor? what's the simplest way to automate this setup? I don't need speed control, just open/close until the roof hits the limit switch.
