I am designing a system that normally only has 2 Emergency Stops. We are adding 2 systems that are not related to the standard machine we are supplying and will not be within sight of the main machine that we typically supply (one with 2 estops) My Colleagues have argued that the Emergency Stops for all 3 machines should be all connected and when any of the 3 machines have an E-stop the other 2 processes will shutdown. I don't agree with the approach because it isn't common sense to shutdown the other 2 machines which have a separate process. This is not a manufacturing line that has many machines that are combining efforts to make one product. What type of arguments could one lend to help distinguish when emergency stops should be connected together to form a common emergency stop? all 3 of these machines/systems are in different rooms.
Thanks for any advice, sarcasm, humor, or intelligence you can lend!!
Mike
Mike
