I have a 200 pulse encoder made by LINE SEIKI Co.-Japan (Model:CB-200HC). I need to connect it to PLC: LG - MASTER K10S1 with HSC inlet connection (VDC) and to program it to cut a fixed length of a steel piece, where a certain length is programmed and a hydraulic press will hold the piece until the saw blade cuts it then a new piece should go forward for next cutting. So the PLC ladder diagram should activate the incoming conveyor with piece on top of it then at a given length given by a preset value it will stop when the encoder value reaches the preset one and the other procedures will follow as they are with no changes at all. I need to connect the PLC to a touch screen so that the preset value will be changed from the screen.
Can you help me in showing me the right connections to be installed between the Encoder/PLC/Touch Screen with the proper ladder diagram for this simple arrangement?
Thank you in advance for your help.
Please contact me on: adjbr1 [at] yahoo.com
Thank you.
Thank you.
