entering ladder logic on Fanuc OT
H
Handasee
We have a problem with a CNC machine and the ladder logic would help to track down the fault. Unfortuately, I do not know the exact keystrokes that will bring up the ladder logic on the CRT of the Fanuc OT.
Any help would be appreciated.
Curt Wuollet
I could be wrong, but I think these are programmed in a Macro language rather than ladder. And I believe they have more than one programming system as well. Pretty spendy if you really have to know whats inside.
cww
W
William Sturm
They do use ladder (called FLadder), but I think that you need to have the right software installed to see it.
Curt Wuollet
Perhaps the same object code and different ways to look at it. The tools in any case, were spendy enough to discourage most folks. If you were a machine tool builder and needed to diddle things they might make sense.
cww
Usually press "System" key---->"PMC"---->"PMCLAD"
You will need an Edit Card for any ladder changes. If the softkey "PMC" is not visible, you'll have to set the appropiate keeprelay, believe its K17.0, or K17.1
