G
Some years back, a DP type flow meter was installed in a Gas line and the linear output of DP Transmitter was fed to a "Linear" integrator. Since then we've been considering those values of Gas flow. The flaw was recently discovered that either the Integrator should have been a Sq. type Integrator or the transmitter itself should have been sq. root type. Now that the mistake has occured is it possible to work upon the "linear" data of yester years and get correct readings?
GST
GST
