H
I have been reading a lot of thing about industrial ethernet.
I have doubt: I understood that HSE and Ethernet/IP operate on the link layers and physics that already exist in the ethernet 802.3 and Profinet doesn't only work with TCP and UDP, he has a direct channel with the layer link. So profinet need a specific hardware.
Thus I could have HSE and Ethernet implemented more easily in the conventional ethernet (for instance, a PC) but the profinet would not be too easy...
That is correct? I would like to receive commentaries.
Thank you.
Thank you.
