G
I would like to know whether a transmitter certified as ex-proof can be used in a intrinsically safe loop?
Just to briefly describe my understanding,
For ex-proof: The transmitter enclosure is designed based on ex-proof concept(enclosure thickness to withstand the explosion & cable entry for flame path)& electronic circuits components may be different from Intrinsically safe instruments(I am not sure).
For Intrinsic safe: This is achieved by limiting the current to the hazardous area using barrier.
With the above info. I feel that a trasmitter certified as ex-proof can be used in instrinsically safe loop provided the ELECTRONICS ARE SAME.Please correct me, if i am wrong.
Also, as per the Rosemount 3051 model there are 3 different certifications:
The code: E5--ex-proof certification; I5--for instrinsic safe certification;I5-for both ex-proof & instrinsic safe;
When we select either one of 3 options whether Rosemount will supply the same transmitters with different certifications for documentation purpose or the electronics are different?
Thanks in advance.
GB
Thanks in advance.
GB
