We are facing an issue with exhaust TC in GE Frame 9E Gas Turbine unit with Mark 6e control system as follows:
When unit is running, TTXD-6 reading fluctuation from normal value to minus value and accordingly Spread is increasing. Once we go for shutdown, TC value is showing steady value but relatively less than other TC (around 15 to 20 C less ). I understand that it looks like loose connection issue. But the confusion is happening due to the following :
During shutdown we tried to investigate the issue, we opened the TC cable from Field Junction box, measured its oh-mic value and mv and found normal. (Please remember that it was showing 20 C less on Mark 6e display). Once we connect the cables back in the Junction Box, it is reading normally and health like other thermocouples. The same phenomena happened 2 times in the same unit.
Still we didn't get the opportunity to go inside the load tunnel and inspect the TC physically as it requires zero speed to access it. I just wanted to know if someone faced the same phenomena earlier or have similar experience to advise.
Thanks in advance
Thanks in advance
