Explosion Proof Solar Cells
T
TonyG
Hi all,
I'm Trying to find out what aspects of a PV cell are important when certifying them for use in a controlled/safe/EXd zone? Is the entire sealed array considered or is it simply the junction box and electrical connections which are important? and whether an un-certified solar panel can be modified so that it could gain a certificate?
Cheers!
Tony
With no replies after several days, I have to assume no forum participants are versed in the procedure, including myself.
Pure speculation leads me to believe all aspects of manufactured unit are important. To what degree will depend on which of the various protection techniques and or methods are to be employed. Emerson published a Bulletin which provides an overview...
http://www.documentation.emersonprocess.com/groups/public/documents/bulletins/d103222x012.pdf
For specifics, I believe you will have to contact one or more of the NRTL's.
Hola,
The equipment is ATEX certificate which specifies the mode of protection of the components. You can only modify the equipment as specified by the certificate. Search the certificate reads it.
ATEX is an EU certification. However, some authorities in other regions may accept the certification.
I believe it is typically better to have/get equipment certified (aka listed, labeled) for the region of use.
If the equipment is not certified who says that can be used in potentially explosive atmospheres? An accredited laboratory certifies that the equipment complies with all regulations.
