Festo CPV-8 Manifold
Jace
Anyone know something about conection betwen festo manifolds in devicenet and controllogix processor.
I try to connect this but manifold not response to commands. i have EDS files for this module and have the config file in RSNetworx for devicenet, module is recognized.
There are several steps you need to perform from NetWorx to get the I/O mapped to the module address space. You must assign the slaves to
the scanner (more than one scanner is permitted on the network, but slaves must be dedicated to one). You must map the data points from the
valve manifold to a specific point in the module image register. There is also a run bit in the output image for the module which must be
set to cause the scanner to, um, scan.
