Hi everyone, We are going to install a fiber optic cable inside a tunnel 10km long. The tunnel is 2 meters in diameter which connects an intake to a hydro electric plant. The headrace tunnel is used to divert the water from a river and have it flow freely via this tunnel to the plant turbine. Now, does anyone know any tips/suggestion on how we may be able to implement this engineering feat with minimum risk? Should we hang this on the highest portion of the tunnel? How far apart will the clamps be on the f.o. cable? What type of f.o. cable should we use? Is the buried type, jelly filled, armored, good enough? Or should we use a duct? Regards, Andre Pablo "Apaul" G. Fausto Nayon Kontrol Systems 354 (44) Quezon Avenue Quezon City, Philippines Tel. +63 2 4485074 Fax. +63 2 4485077
