I am using Hima digital output module F3330 with my AB LED lamps. Hima DO is sending a test pulse of max 6.5V with an interval of 1 sec for 100ms in OFF state which is causing lamps to flicker / blink. I want to filter these test pulses. I have already tried a series resistor but it also dimmed LED brightness in ON state due to voltage drop across resistor. Also tried a 100 uF capacitor in parallel of lamp it worked but started to blow the 100mA fuse. If any of you have came across and resolved such scenario, please help me out. Thanks
BR,
RH
BR,
RH
