F
I'm trying to delete a file on a memory file using FINS command FILE DELETE: 2205. I always have Command Format error. I'm sure I set it correctly as explained in Communications Commands Reference Manual catalog (Cat. No. W342-E1-05).
@CMND(D9050 D9100 D9150)
D9050 #2205
D9051 #8000
D9052 #0001
D9053 #3132
D9054 #3030
D9055 #3032
D9056 #3336
D9057 #2e54
D9058 #5854
D9059 #0000
file nome is 12000236.txt Also try to write File name 2 times like it's in the book... same response
D9150 #0014
D9151 #0006
D9152 #0000
D9153 #0000
D9154 #0F00
D9155 #0000
The response is:
D9100 #2205
D9101 #1004
D9102 #0000
If somebody could send an exemple that is working, I would appreciate it.
Tanks!
Francis
D9050 #2205
D9051 #8000
D9052 #0001
D9053 #3132
D9054 #3030
D9055 #3032
D9056 #3336
D9057 #2e54
D9058 #5854
D9059 #0000
D9150 #0014
D9151 #0006
D9152 #0000
D9153 #0000
D9154 #0F00
D9155 #0000
The response is:
D9100 #2205
D9101 #1004
D9102 #0000
Tanks!
Francis
