I have an application that has several dedicated picture files with a lot of information on each showing the status of a piece of plant. I now have a near identical piece of plant to add to the system with its own PLC. I am going to use this same Fix32 server to poll the second PLC and was wondering if there was a quick way to convert/edit all the existing pictures to create a second set that now points to the second PLC tags. i.e. original picture might point to "plc1:tag1.f_cv", the new picture needs to point to "plc2:tag1.f_cv.
I can obviously produce a report for each PIC, but there doesn't appear to be an option to import a report if I use and find/replace function with a text editor.
It looks like it is going to be a long drawn out process to edit every single picture and expand each grouping very carefully.
