Hello, I am wondering if it is possible for an induction motor in a system could produce harmonics? I had often considered induction motors a non-linear device kind of like a rotating transformer, but I'm told they should only be considered a linear device.
The system in question is an oil well using an electric submersible pump (induction motor driving a fluid pump). The motor is provided power through a three phase cable, let's say about 2500-3000 feet long. The cable is connected to a switchboard at surface, that is fed via a step down transformer from a 60Hz line.
The system voltage is around 1400VAC, and the amps are around 30 amps. The man taking measurements has recorded 3.96% VTHD and 12.4% ITHD. The current harmonic distortion is made up almost entirely 5th order. From what I understand, there are several sites similar to this one on the power line, but he is only seeing this result on a few of the sites. We want to know why the ITHD would be this high. I've attached a photo of the measurement trend.
We have considered possible saturation as an issue, is there anything you folks would check out? Let me know if more info would be helpful!
