what the difference between the displacer switch using mercury switch to actuate the pump or control loop and the float switch the float follow the level? what i know is that the float is motion balance principle to move up and down with the level and displacer use force balance principle
What considerations should i take when i want to select between these two for oil/water seperator or three phase seperator?
