Greeting all,
A flow meter (orifice plate differential pressure) installed on vacuum steam line (-850 mbar).
Mostly the flow is zero (emergency line)
The transmitter connected to the line through impulse tubes with condensate pots.
CASE
The transmitter reads about 80 TPH while actually zero.
After inspection we found that the vacuum sucked all the filled water.
We made sure that there is no leakage at all and filled the pots again.
But after returning the transmitter to the service, again suck all water.
Please advice.
Thanks in advance.
CASE
Please advice.
Thanks in advance.
