L
If I am running a 2 inch pipe at 20PSI of cooling feed water and I run a bypass pipe of 1/2 inch diameter in parallel for 6 feet and then rejoin the 2 inch pipe, will say, a 5% reduction in flow through the main feed pipe be reflected by the exact same 5% reduction in the bypass pipe flow?
