I am looking to the following control problem:
We have a water supply via a pump, the flow is regulated by a flowcontroller (frequency regulator on the pump) who gets his setpoint from a level controller. The water from the pump is fed to four vessels which have all there own flow controller. The goal is to open all four flowcontrollers on the vessels maximum and regulate the pump to minimum energy. The problem is that the flow to the four vessels is not equal due to different pressure losses in the collector.
Does any one has an idea how to solve this problem?
Thanks in advance,
Ronny De Maeyer
Thanks in advance,
Ronny De Maeyer
