I would like to measure a force, in one direction (for exemple the tension in a cable or the force transmitted by steel piece). The measured force is approximately 1500 Newtons. This is a constant force.
There is also a dynamic force of amplitude 40 N.
I would like to be able to measure this dynamic force accurately. For example if the constant force is 1505N, the dynamic force would be 5N.
The problem is that this is in general too small to measure because this 5N can be confused with the noise of the sensor...
Is there a way to do this ? (if we forget about the 1 billion dollars sensor
Thank you very much,
Jack
Jack
