Dear all,
We have Frame 6 30 MW Gas turbine. It has only one mist eliminator which got tripped in overload. After 88QV was restored, we found that the hydraulic oil filter DP has increased by 1 kg/cm2 (0.9 to 1.9) and pinion side temperature in the reduction gear increased by 30 degree C. (76 to 106). For some time this temperature was in the range of 130 deg. C. But externally everything looked fine.
This incident happened on 12th Dec 2021 and on 31st night QV tripped again and again the hydraulic filter DP rose by 1 kg/cm2 but the pinion side RGB temperature was around 106 deg. C. However, after 8 hours of operation vibration in Reduction gear (all three probes) increased and the machine tripped on high vibration.
On inspection it was found that one teeth of the pinion gear was damaged.
So first, what could be the relation between hydraulic filter DP and Mist eliminator. We don't have means to check the main lube oil filter DP. Should we inspect the main lube oil filter too?
What could be the reason for the damage witnessed in the RGB? Poor alignment or something else with the Lube oil circuit?
