R
Hello Again,
Our GT-2 is SpeedTronic MK II Controlled... In Each shutdown we calibrate the cards of the TCP.. (Turbine Control Panel)... We use a Calibration Manual that enlists step-by-step calibration procedure... But there are certain procedures whose physical significance is not properly understood... I seek some help in understanding one such section... Following is the exact writeup as given in GE's Spec Manual...
The Manual Quotes,
Section 13.7 : Excessive Start up Fuel Trip
During this calibration, Gas Fuel will be permitted to flow thru the turbine. To prevent Ignition the spark plugs must be disabled.
13.7.1 : Connect a Digital Voltmeter to the SRV's Servo Drive Voltage Pin.
13.7.2 : Temporarily disable the VMPA (Trip Card) Function.
13.7.3 : Place the Operation Selector Switch in "FIRE" and give the unit a normal start signal. When the SRV and GCV open and stabilize at their Firing Fuel Positions, Record the Voltage at "SRV's Servo Drive Voltage Pin".
13.7.4 : While Still in the Firing Sequence, Establish VCE = 10V. (In MK II this can be done by shorting two pins of a Card). This will cause GCV to go full open and SRV to open further (Pl. Note that in MK II SRV Opens fully at 9.25V). When the SRV position stabilizes, record the Voltage at "SRV's Servo Drive Voltage Pin". As soon as the reading is taken shut of the Gas Fuel flow by turning the Operation Selector Switch back to "CRANK" position.
13.7.5 : Calculate the "Excess Fuel Trip Voltage" as follows :
Excessive Fuel Trip Setpoint = [ Fire Stroke Volts, Step 13.7.3 ] + 0.5*[ (Full Stroke Volts, Step 13.7.4) - (Fire Stroke Volts, Step 13.7.3) ]
13.7.6 : Now Set VCE to Zero using Manual VCE POT. Allow this VCE to control the position of SRV by jumpering J1 and J2 on SRV Drive Card. (In MK II, by jumpering these points VCE is directly fed to SRV).. Remove GCV Drive Card to ensure that GCV remains shut.
13.7.7 : Slowly increase VCE untill the voltage at "SRV's Servo Drive Voltage Pin" equals the Excess Fuel Trip Voltage calculated in Step 13.7.5
13.7.8 : Observe the "Fault" light on the SRV Drive Card and adjust The Trip Reference Pot so that the "Fault" light just comes on.
13.7.9 : Give the Unit a stop signal.
13.7.10 : With Spark plugs removed, all cards in place and all jumpers removed, give the turbine a normal start signal with master operation switch in the "Fire" position. Confirm that the unit does not trip with the GCV in its normal firing position.
13.7.11 : While still within the Firing Time, turn the Manual VCE POT untill VCE is reduced slightly from it's firing value. Install a jumper to make VCE Maximum. (In MK II this can be done by shorting two pins of a Card).
13.7.12 : Increase VCE with the Manual VCE POT and confirm that the unit trips when the voltage at "SRV's Servo Drive Voltage Pin" reaches the value calculated in step 13.7.5.
13.7.13 : Remove all jumpers and test equipment. Reset Max VCE as per control specs.
13.7.14 : Purge the turbine by cranking the unit for 2 mins.
13.7.15 : Reconnect spark plugs.
First of all, what's the exact significance of this calibration procedure... Is such a thing taken care of in MK V system too??
au revoir
Rahul
The Manual Quotes,
au revoir
Rahul
