On site we have a GE generator with Mark VI control system. The logic has the island mode scheme, when there is a load rejection somewhere upstream to the grid the turbine increases speed with a specific acceleration and when this happens the turbne goes to island mode supplying the auxiliaries of the plant.
During the island mode operation the gas turbine keeps constant speed and the generator runs at 49.94 Hz, slightly lower than the 50Hz of the grid. The auto synch function of the line breaker (52L) did not work becasue the synch scope rotated counter-clockwise and there is no facility to increase the frequnecy by increasing the gas through SRV.
Can you advise on this issue? GE was made aware but with no actual work on that item. When you synchronize to the 52G breaker the turbine runs at 100.3% of nominal speed so the generator is alwways higher than the grid in order to have bumpless synch.
